When I export a csv, penzd file I only get the pen& z, no description. Any ideas?
See this post…. Where does code description get saved? - #4 by kornel.nemeti
May not be possible in that exact export format.
Hi @dlwls6152,
To export survey data as a CSV file from Emlid Reach devices, you can follow these steps:
- Open Emlid Flow App:
- Launch the app on your mobile device and connect to your Reach receiver.
- Access the Project:
- Go to the “Projects” section and select the project that contains the data you want to export.
- Export the Data:
- Inside the project, tap on the “Export” option.
- Choose the export format as CSV.
- Configure the export settings, including the coordinate system and delimiter options if necessary.
- Download the Files:
- Once the export is complete, you should see a download option for the CSV file, which contains your survey data.
If you’re only getting .pen
and .z
files, it’s likely that you’re trying to export raw data logs. These are the raw GNSS data formats used for post-processing (PENZD is a file format typically for RTK and PPK data).
To export a CSV (for processed survey data), ensure you’re in the “Survey” or “Project” tab rather than “Logs.”
