When we export global shape there is a difference between Android and iOS. In the Android export there is a 5th file in the zip folder. The projection file .prj is completely missing in the iOS export. What is the reason? Thanks in advance.
Hi @Dgrem,
Welcome to our community!
I tried to reproduce this case. I exported a Shapefile from iOS, Android, and Emlid Flow360.
The ZIP file will contain a .prj file if you export a project with any local coordinate system. If you export a project with the global coordinate system, you don’t get any. prj files. The reason for this is that the .prj file is required because it defines a projection of the local coordinate system. It should work the same way on all platforms.
Thank you. Absolutly right.
