That looks like a nice setup. I don’t see any problems.
I’m not sure on rctimer motors as I have not used them before. Give them a shot if the price is right.
On a side note:
You have plenty of throttle so you could increase battery size (5000mah to 5500mah or bigger) and still have good hover. Remember to include the extra weight!
@aquila thank you ! I will increase the batterysize with 20/30C instead of 30/40C in order to save weight (I have tested with eCalc and it’s pretty much the same performance…)
I keep you updated once I receive all my stuff !
I bought everything but it appears that my motors (RCTIMER SL2212. http://rctimer.com/product-1150.html) are mounted with a DJI HUB (self locking system) and I can’t use my GWS propellers 11x4.7
I also searched for new props but there is only 9" props with self locking system…
I don’t know what to do…
Is there any adapters for change the prop system ?
do the 9.4x4.3 or 4.5 prop will be ok if there is no adapters ?
One other solution could b e to force the GWS props into the motor screw (I tried it, and I can lock the prop with the nut but it’s pretty hard to remove), or adapt the hole of the props to fit the self locking mount…
I don’t know about this one. Maybe check ali express for the props you need. I have found things on there i don’t see elsewhere.
If you do any mods to the props, the only thing I would say is insure they do lock in place very securely and insure the mod does not mess with the balance of the prop.
@P3G I am not sure if you are still on the platform as this thread is 7 years old but I really wanted your feedback on the RCTimer SL2212 920KV motor as I am planning to use those motors in my swarm of 50 drones. I would be really grateful if you can provide your review of the motor and can reach back to me either here or preferably on my email at: bilalarif.pm@gmail.com. Thank you! I am awaiting your response.
