The ESC calibration step needs a local document. The Ardupilot instructions cover other controllers, but following that set of steps leads to either no calibration, or reversed throttle (sometimes, don’t know why. After a dozen attampts, I am pretty sure I am following the instructions to the letter. Can anyone share the correct order of things to calibrate ESCs?
I am sure you are right about RC3_REV being set wrong, but when I search for the RC parameters in Mission Planner, nothing shows up. Comparing screenshots to what I actually see in Mission Planner, only Standard Parameters are listed. I must be running in some kind of “Easy Mode”. Any ideas?
I have calibrated all other things. Yes, the throttle does move, although to be honest, I don’t recall if it moves opposite the stick, or with it. If I am not mistaken, it should be moving opposite my stick since RC3-REV = 1. Is that right? I can check that out.
I will have some time tonight, so I will make a troubleshooting video to illustrate what is happening.
OK, so for future travelers using a Futaba T8FG Super, you will need to reverse throttle on the transmitter AND RC3_REV = 1.
I have no idea why this should be the case, but sure enough, when I ran the radio calibration, I could see that the throttle was reversed, so I checked the transmitter setting, and channel 3 was set to NORMAL. After I changed it to REVERSED, everything ran as expected. First time! Thanks all for the help.
