Thanks. Output of sudo journalctl -u ardurover
is:
-- Logs begin at Thu 2016-11-03 17:16:42 UTC, end at Tue 2018-05-29 15:26:35 UTC. --
May 29 14:23:19 navio systemd[1]: Started ArduPilot for Linux.
May 29 14:23:19 navio sh[335]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
May 29 14:23:19 navio sh[335]: scan:688: scan past end of eeprom
May 29 14:23:19 navio sh[335]: Raspberry Pi 3 Model B Plus Rev 1.3. (intern: 2)
May 29 14:23:20 navio systemd[1]: ardurover.service: Main process exited, code=exited, status=1/FAILURE
May 29 14:23:20 navio systemd[1]: ardurover.service: Unit entered failed state.
May 29 14:23:20 navio systemd[1]: ardurover.service: Failed with result 'exit-code'.
May 29 14:23:20 navio systemd[1]: ardurover.service: Service hold-off time over, scheduling restart.
May 29 14:23:20 navio systemd[1]: Stopped ArduPilot for Linux.
May 29 14:23:20 navio systemd[1]: Started ArduPilot for Linux.
May 29 14:23:20 navio sh[439]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
May 29 14:23:20 navio sh[439]: scan:688: scan past end of eeprom
May 29 14:23:20 navio sh[439]: Raspberry Pi 3 Model B Plus Rev 1.3. (intern: 2)
May 29 14:23:20 navio sh[449]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
May 29 14:23:20 navio sh[449]: scan:688: scan past end of eeprom
May 29 14:23:20 navio sh[449]: Raspberry Pi 3 Model B Plus Rev 1.3. (intern: 2)
May 29 14:23:21 navio systemd[1]: ardurover.service: Service hold-off time over, scheduling restart.
May 29 14:23:21 navio systemd[1]: Stopped ArduPilot for Linux.
May 29 14:23:21 navio systemd[1]: Started ArduPilot for Linux.
May 29 14:23:21 navio sh[457]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
May 29 14:23:21 navio sh[457]: scan:688: scan past end of eeprom
May 29 14:23:21 navio sh[457]: Raspberry Pi 3 Model B Plus Rev 1.3. (intern: 2)
May 29 14:23:21 navio systemd[1]: ardurover.service: Main process exited, code=exited, status=1/FAILURE
May 29 14:23:21 navio systemd[1]: ardurover.service: Unit entered failed state.
May 29 14:23:21 navio systemd[1]: ardurover.service: Failed with result 'exit-code'.
May 29 14:23:21 navio sh[467]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
May 29 14:23:21 navio sh[467]: scan:688: scan past end of eeprom
May 29 14:23:21 navio sh[467]: Raspberry Pi 3 Model B Plus Rev 1.3. (intern: 2)
May 29 14:23:21 navio systemd[1]: ardurover.service: Start request repeated too quickly.
May 29 14:23:21 navio systemd[1]: Failed to start ArduPilot for Linux.
May 29 14:24:05 navio systemd[1]: Started ArduPilot for Linux.
May 29 14:24:05 navio sh[711]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
May 29 14:24:05 navio sh[711]: scan:688: scan past end of eeprom
May 29 14:24:05 navio sh[711]: Raspberry Pi 3 Model B Plus Rev 1.3. (intern: 2)
May 29 14:24:05 navio systemd[1]: ardurover.service: Main process exited, code=exited, status=1/FAILURE
May 29 14:24:05 navio systemd[1]: ardurover.service: Unit entered failed state.
May 29 14:24:05 navio systemd[1]: ardurover.service: Failed with result 'exit-code'.
May 29 14:24:05 navio systemd[1]: ardurover.service: Service hold-off time over, scheduling restart.
May 29 14:24:05 navio systemd[1]: Stopped ArduPilot for Linux.
May 29 14:24:05 navio sh[719]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
May 29 14:24:05 navio sh[719]: scan:688: scan past end of eeprom
May 29 14:24:05 navio sh[719]: Raspberry Pi 3 Model B Plus Rev 1.3. (intern: 2)
May 29 14:24:05 navio sh[727]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
May 29 14:24:05 navio sh[727]: scan:688: scan past end of eeprom
May 29 14:24:05 navio sh[727]: Raspberry Pi 3 Model B Plus Rev 1.3. (intern: 2)
May 29 14:24:06 navio systemd[1]: ardurover.service: Service hold-off time over, scheduling restart.
May 29 14:24:06 navio systemd[1]: Stopped ArduPilot for Linux.
May 29 14:24:06 navio systemd[1]: Started ArduPilot for Linux.
May 29 14:24:06 navio sh[735]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
May 29 14:24:06 navio sh[735]: scan:688: scan past end of eeprom
May 29 14:24:06 navio sh[735]: Raspberry Pi 3 Model B Plus Rev 1.3. (intern: 2)
May 29 14:24:06 navio systemd[1]: ardurover.service: Main process exited, code=exited, status=1/FAILURE
May 29 14:24:06 navio systemd[1]: ardurover.service: Unit entered failed state.
May 29 14:24:06 navio systemd[1]: ardurover.service: Failed with result 'exit-code'.
May 29 14:24:06 navio sh[743]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
May 29 14:24:06 navio sh[743]: scan:688: scan past end of eeprom
May 29 14:24:06 navio sh[743]: Raspberry Pi 3 Model B Plus Rev 1.3. (intern: 2)
May 29 14:24:06 navio systemd[1]: ardurover.service: Start request repeated too quickly.
May 29 14:24:06 navio systemd[1]: Failed to start ArduPilot for Linux.
May 29 14:27:26 navio systemd[1]: Started ArduPilot for Linux.
May 29 14:27:26 navio sh[886]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
May 29 14:27:26 navio sh[886]: scan:688: scan past end of eeprom
May 29 14:27:26 navio sh[886]: Raspberry Pi 3 Model B Plus Rev 1.3. (intern: 2)
May 29 14:27:26 navio systemd[1]: ardurover.service: Main process exited, code=exited, status=1/FAILURE
May 29 14:27:26 navio systemd[1]: ardurover.service: Unit entered failed state.
May 29 14:27:26 navio systemd[1]: ardurover.service: Failed with result 'exit-code'.
May 29 14:27:26 navio systemd[1]: ardurover.service: Service hold-off time over, scheduling restart.
May 29 14:27:26 navio systemd[1]: Stopped ArduPilot for Linux.
May 29 14:27:26 navio sh[894]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
May 29 14:27:26 navio sh[894]: scan:688: scan past end of eeprom
May 29 14:27:26 navio sh[894]: Raspberry Pi 3 Model B Plus Rev 1.3. (intern: 2)
May 29 14:27:26 navio sh[902]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
May 29 14:27:26 navio sh[902]: scan:688: scan past end of eeprom
May 29 14:27:26 navio sh[902]: Raspberry Pi 3 Model B Plus Rev 1.3. (intern: 2)
May 29 14:27:27 navio systemd[1]: ardurover.service: Service hold-off time over, scheduling restart.
May 29 14:27:27 navio systemd[1]: Stopped ArduPilot for Linux.
May 29 14:27:27 navio systemd[1]: Started ArduPilot for Linux.
May 29 14:27:27 navio sh[910]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
May 29 14:27:27 navio sh[910]: scan:688: scan past end of eeprom
May 29 14:27:27 navio sh[910]: Raspberry Pi 3 Model B Plus Rev 1.3. (intern: 2)
May 29 14:27:27 navio systemd[1]: ardurover.service: Main process exited, code=exited, status=1/FAILURE
May 29 14:27:27 navio systemd[1]: ardurover.service: Unit entered failed state.
May 29 14:27:27 navio systemd[1]: ardurover.service: Failed with result 'exit-code'.
May 29 14:27:27 navio sh[918]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
May 29 14:27:27 navio sh[918]: scan:688: scan past end of eeprom
May 29 14:27:27 navio sh[918]: Raspberry Pi 3 Model B Plus Rev 1.3. (intern: 2)
May 29 14:27:27 navio systemd[1]: ardurover.service: Start request repeated too quickly.
May 29 14:27:27 navio systemd[1]: Failed to start ArduPilot for Linux.
May 29 15:20:54 navio systemd[1]: Started ArduPilot for Linux.
May 29 15:20:54 navio sh[1024]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
May 29 15:20:54 navio sh[1024]: scan:688: scan past end of eeprom
May 29 15:20:54 navio sh[1024]: Raspberry Pi 3 Model B Plus Rev 1.3. (intern: 2)
May 29 15:20:54 navio systemd[1]: ardurover.service: Main process exited, code=exited, status=1/FAILURE
May 29 15:20:54 navio systemd[1]: ardurover.service: Unit entered failed state.
May 29 15:20:54 navio systemd[1]: ardurover.service: Failed with result 'exit-code'.
May 29 15:20:54 navio systemd[1]: ardurover.service: Service hold-off time over, scheduling restart.
May 29 15:20:54 navio systemd[1]: Stopped ArduPilot for Linux.
May 29 15:20:54 navio sh[1033]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
May 29 15:20:54 navio sh[1033]: scan:688: scan past end of eeprom
May 29 15:20:54 navio sh[1033]: Raspberry Pi 3 Model B Plus Rev 1.3. (intern: 2)
May 29 15:20:54 navio sh[1042]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
May 29 15:20:54 navio sh[1042]: scan:688: scan past end of eeprom
May 29 15:20:54 navio sh[1042]: Raspberry Pi 3 Model B Plus Rev 1.3. (intern: 2)
May 29 15:20:55 navio systemd[1]: ardurover.service: Service hold-off time over, scheduling restart.
May 29 15:20:55 navio systemd[1]: Stopped ArduPilot for Linux.
May 29 15:20:55 navio systemd[1]: Started ArduPilot for Linux.
May 29 15:20:55 navio sh[1051]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
May 29 15:20:55 navio sh[1051]: scan:688: scan past end of eeprom
May 29 15:20:55 navio sh[1051]: Raspberry Pi 3 Model B Plus Rev 1.3. (intern: 2)
May 29 15:20:55 navio systemd[1]: ardurover.service: Main process exited, code=exited, status=1/FAILURE
May 29 15:20:55 navio systemd[1]: ardurover.service: Unit entered failed state.
May 29 15:20:55 navio systemd[1]: ardurover.service: Failed with result 'exit-code'.
May 29 15:20:55 navio sh[1059]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
May 29 15:20:55 navio sh[1059]: scan:688: scan past end of eeprom
May 29 15:20:55 navio sh[1059]: Raspberry Pi 3 Model B Plus Rev 1.3. (intern: 2)
May 29 15:20:55 navio systemd[1]: ardurover.service: Start request repeated too quickly.
May 29 15:20:55 navio systemd[1]: Failed to start ArduPilot for Linux.
