I am using Emlid Studio 1.9.
I have been able to successfully geotag all the other folders of the flight, but on the last one I am getting an error MRK Processing Failed: Failed to get solutions from […].pos (InvalidInputFiles). I am using the same workflow I have been for the others. Anyone had this happen before?
The files being used are:
- DJI Drone OBS File
- DJI Drone NAV File
- Rinex file from Base Station
- DJI Drone MRK File
When clicking process to produce the .POS file, it says “UNKNOWN at HH:MM:SS” instead of the usual “FIX at HH:MM:SS” Once the green bar shows it has gone through everything, I get the error “Something Went Wrong”, from the technical report is this:
[08:25:38.565] [post-processing] [I] Post-processing finished: [rtklibwrapper::Result = status:Error, value:[rtklibwrapper::SolutionFiles = solutionFile:, eventsFile:], errorMsg:MRK processing failed: Failed to get solutions from ‘C:\Users\gillm\AppData\Local\Temp\PostProcessor-d9ad1294bb92c4a9\DJI_202503301307_016_DMZAvyPath_PPKOBS.pos’ (InvalidInputFiles)]
