I am using 2 RS+ units. When I measure my RS + with RV, I get the same measurement result as on the RV3 with WGS84.
If I switch to MGI / Austria GK Central EPSG:31255 in the RV3, I get a wrong result.
Data from my RS +
13.74914758969
48.394227850770015
Measured value from ReachView 3
30853.03 m E (Error 0,45 m)
361867.94 m N (Error 0,13 m)
Please enter the Latitude, Longitude, and Height in ETRS89 in the Base coordinates window.
WGS84 and ETRS89 coordinate systems are quite close to each other. However, they are not the same. If the base transmits corrections in WGS84, and the rover transforms the result to MGI / Austria GK Central considering the corrections are in ETRS89, the shift may appear. That’s why it’s important to enter the base coordinates in ETRS89.
I had a displacement of about 47cm in my base.
Now I have re-measured my base with a survey point from the surveying office in RV3.
Thanks for your support, I’ve solved the problem.
