ERROR: Emlid Studio 'Nav file has no data'
Hello all, this error is a first for me. Any troubleshooting ideas would be much appreciated!
The .nav file is from a DJI M3E and clearly contains data when opened in Notepad or TextEdit.
Here are the raw data files:
Running Emlid Studio v1.90
Hi Milo,
Thanks for sharing all the data! I’ve processed the same set of logs. With the default settings everything processed fine using the DJI navigation file. The file itself looks fine.
Does the processing still fails on your end? Could you please double-check the settings you used and let me know if anything was changed from the default? It’d help us narrow down where the difference might be coming from.
DJI_202512231358_015_1186khenipsenflight_PPKOBS.pos (219.3 KB)
DJI_202512231358_015_1186khenipsenflight_PPKOBS_events.pos (14.0 KB)
Hello @inkar.madikyzy thank you very much for the reply, your success encouraged me to troubleshoot deeper.
Turns out it was a simple folder permissions issue in MacOS (15.6.1). I moved the drone .obs, .nav & .mrk files from my Documents folder to Downloads and Emlid Studio from there and it worked without error!
I just checked my permissions settings for Emlid Studio & Documents was indeed unchecked.
Didn’t think to check that because I’ve processed from this computer before without issue.
Anyway, thanks again for your help.
Thanks for updating me! Permissions like these are easy to overlook. I’m glad you got to the bottom of it :+1:
