Enable GPS message NAV_VELNED using c++
Hi i would like to enable the NAV_VELNED message in order to read velocity data from GPS but i’m not able to enable it.
I am trying to use the code provided by Emlid to enable NAV_POSLLH and i’ve done something like this:
int Ublox::enableNAV_VELNED()
    unsigned char gps_nav_status[] = {0xb5, 0x62, 0x06, 0x01, 0x12, 0x00, 0x01, 0x12, 0x01, 0x70, 0x2A};
    int gps_nav_status_length = (sizeof(gps_nav_status)/sizeof(*gps_nav_status));
    unsigned char from_gps_data_nav[gps_nav_status_length];
    return SPIdev::transfer(spi_device_name.c_str(), gps_nav_status, from_gps_data_nav, gps_nav_status_length, 200000);
I think the the HEX code for the NAV_VELNED is wrong. How can i find the last 2 bytes related to the checksum? Thank you!
Hi @srp,
I see that Lars has shared his part of the code with you in the other thread. Please check this out:
Thanks. Unfortunately it doesn’t seem to work for me
Oh, I see. I can hardly help with the custom code but hopefully, the additional comments from Lars will help to shed some light on this.
