@george.staroselskiy
no
pi@192.168.1.150’s password:
Linux navio 4.9.45-94f47ec-emlid-v7+ #4 SMP PREEMPT Wed Aug 30 18:17:43 MSK 2017 armv7l
STEP 1:
Choose your vehicle and ArduPilot version using emlidtool
(Please, read carefully all options and select appropriate one for either Navio 2 or Navio+)
STEP 2:
Set your GCS IP
- sudo nano /etc/default/arducopter
- sudo nano /etc/default/arduplane
- sudo nano /etc/default/ardurover
STEP 3:
Reload configuration by issuing these commands
- sudo systemctl daemon-reload
Launch, and enable on boot
IMPORTANT:
To show this message one more time type “sudo emlidtool ardupilot help”
SSH is enabled and the default password for the ‘pi’ user has not been changed.
This is a security risk - please login as the ‘pi’ user and type ‘passwd’ to set a new password.
pi@navio:~ $ sudo pip uninstall emlidtool && sudo pip install -U emlidtool
Cannot uninstall requirement emlidtool, not installed
pi@navio:~ $
and trying to install also impossible
pi@navio:~ $ sudo pip install -U emlidtool
Collecting emlidtool
Exception:
Traceback (most recent call last):
File “/usr/lib/python2.7/dist-packages/pip/basecommand.py”, line 215, in main
status = self.run(options, args)
File “/usr/lib/python2.7/dist-packages/pip/commands/install.py”, line 353, in run
wb.build(autobuilding=True)
File “/usr/lib/python2.7/dist-packages/pip/wheel.py”, line 749, in build
self.requirement_set.prepare_files(self.finder)
File “/usr/lib/python2.7/dist-packages/pip/req/req_set.py”, line 380, in prepare_files
ignore_dependencies=self.ignore_dependencies))
File “/usr/lib/python2.7/dist-packages/pip/req/req_set.py”, line 554, in _prepare_file
require_hashes
File “/usr/lib/python2.7/dist-packages/pip/req/req_install.py”, line 278, in populate_link
self.link = finder.find_requirement(self, upgrade)
File “/usr/lib/python2.7/dist-packages/pip/index.py”, line 465, in find_requirement
all_candidates = self.find_all_candidates(req.name)
File “/usr/lib/python2.7/dist-packages/pip/index.py”, line 423, in find_all_candidates
for page in self._get_pages(url_locations, project_name):
File “/usr/lib/python2.7/dist-packages/pip/index.py”, line 568, in _get_pages
page = self._get_page(location)
File “/usr/lib/python2.7/dist-packages/pip/index.py”, line 683, in _get_page
return HTMLPage.get_page(link, session=self.session)
File “/usr/lib/python2.7/dist-packages/pip/index.py”, line 792, in get_page
"Cache-Control": “max-age=600”,
File “/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py”, line 501, in get
return self.request(‘GET’, url, **kwargs)
File “/usr/lib/python2.7/dist-packages/pip/download.py”, line 386, in request
return super(PipSession, self).request(method, url, *args, **kwargs)
File “/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py”, line 488, in request
resp = self.send(prep, **send_kwargs)
File “/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py”, line 609, in send
r = adapter.send(request, **kwargs)
File “/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py”, line 47, in send
resp = super(CacheControlAdapter, self).send(request, **kw)
File “/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/adapters.py”, line 423, in send
timeout=timeout
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 643, in urlopen
_stacktrace=sys.exc_info()[2])
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/retry.py”, line 315, in increment
total -= 1
TypeError: unsupported operand type(s) for -=: ‘Retry’ and 'int’
pi@navio:~ $
or
pi@navio:~ $ sudo pip3 install -U emlidtool
Exception:
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 594, in urlopen
chunked=chunked)
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 350, in _make_request
self._validate_conn(conn)
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 837, in validate_conn
conn.connect()
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connection.py”, line 323, in connect
ssl_context=context)
File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/ssl.py", line 324, in ssl_wrap_socket
return context.wrap_socket(sock, server_hostname=server_hostname)
File “/usr/lib/python3.5/ssl.py”, line 385, in wrap_socket
_context=self)
File “/usr/lib/python3.5/ssl.py”, line 760, in init
self.do_handshake()
File “/usr/lib/python3.5/ssl.py”, line 996, in do_handshake
self._sslobj.do_handshake()
File “/usr/lib/python3.5/ssl.py”, line 641, in do_handshake
ConnectionResetError: [Errno 104] Connection reset by peer
During handling of the above exception, another exception occurred:
File “/usr/lib/python3/dist-packages/pip/basecommand.py”, line 215, in main
File “/usr/lib/python3/dist-packages/pip/commands/install.py”, line 353, in run
File “/usr/lib/python3/dist-packages/pip/wheel.py”, line 749, in build
File “/usr/lib/python3/dist-packages/pip/req/req_set.py”, line 380, in prepare_files
File “/usr/lib/python3/dist-packages/pip/req/req_set.py”, line 554, in _prepare_file
require_hashes
File “/usr/lib/python3/dist-packages/pip/req/req_install.py”, line 278, in populate_link
File “/usr/lib/python3/dist-packages/pip/index.py”, line 465, in find_requirement
File “/usr/lib/python3/dist-packages/pip/index.py”, line 423, in find_all_candidates
File “/usr/lib/python3/dist-packages/pip/index.py”, line 568, in _get_pages
File “/usr/lib/python3/dist-packages/pip/index.py”, line 683, in _get_page
File “/usr/lib/python3/dist-packages/pip/index.py”, line 792, in get_page
File “/usr/lib/python3/dist-packages/pip/download.py”, line 386, in request
timeout=timeout
total -= 1
pi@navio:~ $
but if trying to install with apt it says already installed
pi@navio:~ $ sudo apt-get install emlidtool
Reading package lists… Done
Building dependency tree
Reading state information… Done
emlidtool is already the newest version (1.0.4-1).
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
pi@navio:~ $
but not on path ??
pi@navio:~ $ sudo emlidtool ardupilot
sudo: emlidtool: command not found
pi@navio:~ $
