Emlid Studio Mavic 3E PPK Issues
Good afternoon. I recently purchased a Mavic 3E. I have been flying it with RTK but wanted to try and run the data thru PPK solution in Emlid Studio. When I use the files that DJI downloads directly to the directory I cant seen to get a fix solution. I wonder if there is a setting in processing that im missing? Is there a tutorial that might be available?
Thanks
Do you have the logs from your corrections source as well?
Hi Chris,
It’s hard to say something without checking the logs. Can you please share them? You can send them to support@emlid.com with a link to this thread.
Maybe this is related. I am also processing M3E photos through Emlid Studio but when I import it into Metashape, the accuracy of the photos aren’t being imported with it. I’m using a CORs NTRIP network RTK solution for the RTK’d photos. I’m using the exact same base station for PPK processing as well.
