Emlid Studio freezes consistently at the same timestamp during PPK processing
Hi everyone,
I’m having trouble processing one specific DJI PPK dataset in Emlid Studio and would appreciate any suggestions.
We are using DJI Mavic E3 RTK drone and Norwegian ETPOS base station observations.
Emlid Studio starts processing normally but always becomes unresponsive at exactly:
2026-09-24 16:51:58 (viz. images)
The application freezes and CPU usage drops to 0%. The Cancel button also becomes unresponsive.
  1. Other flights from the same field campaign process successfully using the same workflow and the same base station
  2. Base station RINEX appears normal through and beyond the freeze timestamp
  3. Rover OBS also continues normally beyond the freeze timestamp
As a new user Im not allowed to upload the Drone.obs or Base_station.rnx files to the post
Thank you for any help or suggestions
Provide a download link
Hi @kopyandriv, welcome to the community!
I will need to look at the data more closely. Could you share the data via a cloud-sharing folder link? Feel free to send it to [email protected] as well. I will check it further.
Thanks for the answers
Here is a link to the files:
EMLID
Hi @kopyandriv,
Thank you for sharing the file! I checked the data, and I can reproduce the issue as well. I agree that both the base and rover data are good. The issue appears to come from the navigation file. There is some missing satellite data in the navigation file. I suggest downloading the navigation file from the CORS data and reprocessing it. If the issue still persists, please share the navigation file from the base. I will check it further!
