Hi Emlid Community:
When I use the option “Use base observations” set to Off in Emlid Studio > “Drone data processing”, my POS and Events.pos files are empty / no records. There are header lines.
If I wait for base station data to become available (next day) and process with “Use base observations” set to On, yes I do get POS and Event.pos records and everything looks great.
Why do I want to process without base data?
I am testing capturing trigger events off the camera hot-shoe with an M2. I want to quickly see results with the 20cm XY / 40cm Z accuracy reported live by the M2. I want to verify I am not dropping camera trigger events and try to measure the lag between camera triggers and GNSS event timestamps.
Am I correct in thinking “Use base observations” set to Off should still output POS and Event records?
My M2 is running firmware 30.1
I have tried this on Emlid Studio 1.4 and 1.5
Here are ZIP files of my UBX file and RINEX from my local CORS station in Golden, CO:
ctmc097.zip (4.2 MB)
localhost_raw_20230407222732_UBX.zip (4.9 MB)
Thank you,
Joe
