I’m testing our Reach RS*. I setup the Base and Rover and waited until they had fixed positions.
Then I measured 3 points closeby (under 10m distance).
I repeated the process with the exact locations again to compare data.
My problems are:
1- When trying to post process in EmlidStudio, after selecting the rinex files for both Rover and Base the final result has 87% float results, 9%fixed results and 14% single.
If I took all the points while having a Fix between base and rover, why did this happen?
2- If I ignore post processing and simply analyse the cvs file from each project export, I can see a differente in elevation of over 8cms
What I’m I doing wrong?
Thanks
