Hi all,
I have Studio version 1.1 installed on my HP Laptop
The copies I have running on 2 other computers update without issue, however, this one seems stuck at Ver 1.1
I have tried to uninstall and that also will not work
My Computer specs are:
|Processor|Intel(R) Core™ i7-7500U CPU @ 2.70GHz 2.90 GHz|
|Installed RAM|6.00 GB|
|System type|64-bit operating system, x64-based processor|
OS info:
|Edition|Windows 10 Pro|
|Version|22H2|
|Installed on|1 Oct 2020|
|OS build|19045.2364|
|Experience|Windows Feature Experience Pack 120.2212.4190.0|
Any suggestions?
Hi Adrian,
I’d suggest installing the new version from our docs manually, but it’s strange that you can’t uninstall the old one. What happens at this step? Do you see any errors?
Hi kseniia
N\When I try to delete the app I receive no error messages.
Nothing happens
No response
Very strange indeed
It seems I may have to go to the root directory and manually delete the files.
However, I am hesitant to do this because I don’t know if any job files or settings might be located there
I have tried your suggestion previously and receive this message:
“The directory you selected already exists and contains an installation. Choose a different target for installation.”
So I simply renamed the folder to “Emlid Studio 2” and it accepted the updated app
However, that still leaves me with a duplicated program folder - no?
Adrian,
So, now you have a working Emlid Studio on the last version and the older Emlid Studio 1.1 installed in different folders, right? Does the Emlid Studio 1.1 work well, except for not suggesting an update and issues with uninstalling?
Yes. Your conclusions are correct
Hi Adrian,
You can try to delete Emlid Studio 1.1 like this: go to the app root directory, open MaintenanceTool.exe
→ Remove all components. Did you try that?
Also, may I ask you to send me your Emlid Studio logs to DM? I’d like to investigate possible reasons for the update failure. You may follow these steps to extract the logs:
- Press Windows + R to open the “Run” window.
- Paste
%APPDATA%\..\Local\Emlid\Emlid Studio
in and press Enter.
- An Explorer windows should pop up with
Emlid Studio
data folder. There should be the logs
directory, which you should compress and send it to me.
To compress it, you should right-click → Send to → Compressed (zipped) folder.
Thanks!
Hi Gleb
These look like great, comprehensive instructions.
I will try them over the weekend when i have access to the computer and send you the files.
Thank you
Hi Adrian,
How is it going? Did you have a chance to try Gleb’s suggestions?
