What format should the serial output coming from the reach be in? The solution output in the Reach app is set to serial. We have the serial connected to an Arduino Mega 2560 which in turn is connected via usb to the pc. We are hoping to print latitude, longitude, and elevation, along with a timestamp. Will this work?
What version of ReachView are you using(check the gear tab)? Try updating to the latest one(v0.1.0), as it simplifies work with serial devices.
What you want can be achieved by setting solution output to Serial->UART with llh format. The stream will not start until single solution is achieved though.
The app is 0.0.5. I can’t get it to update. When we click update it says updating, but after it is finished we reconnect to the app and it still says 0.0.5. What should we do?
