We developed the Android application Apglos Survey Wizard.
According to us this application is a great match with the Emlid Reach RS2. We want to keep on improving Apglos Survey Wizard. So we want to ask you to download it (https://www.apglos.eu/asw) and try it.
Tell us your opinions and your ideas so we can integrate those in Apglos Survey Wizard.
Serieus reactions will be rewarded with credits for Apglos Survey Wizard.
Yes we support UTM. In Other settings you can chose the country you are in and the ellipsoid you are using. Then you can select the CRS like the UTM.
If your country is not in the list yet, then let us know so we can add your country. We only need to know which geoid to use and where we get obtain the geoid file.
Hi Hanno. We’re looking to test Apglos with the RS2 to offer our clients. Malaysia’s not in the list, but I also can’t seem to be able to add a custom CRS in the settings.
What I mean by localization is the ability to work with surface coordinates. This is done by setting up the base in any position and then creating a control network by occupying known control points that may or may not be on a true WGS84 alignment. This is not creating a custom grid reference that is tied to any other known coordinate systems.
Thanks for the information. We can add the Malaysian CRS within one week. I will let you know when it is integrated.
The option “New Local” is for doing Localization. We are testing with adding your own local parameters for your own CRS, but we are still working on the reading of your own geoid file.
