I am using Emlid flight controller kit. Everything is working perfectly except that the power module is showing wrong voltage on QGroundControl. I have connected power module to PWR1 port and selected Edge PWR1 option in QGroundControl. I also tried other option in power module setting in QGroundControl but got no success. What am i doing wrong.
Besides, the power module is getting heat up a little bit. Is that normal.
Hi @amitmanish,
What do you mean by wrong voltage? Could you please clarify what’s the difference between the voltage value in QGC and the real one?
It’d be great if you post a screenshot showing the issue here.
What’s the voltage of the battery you use?
