Sorry for the delayed response. I saw your emails, but I’ll answer you in this thread as the answer might be useful for other users.
We’ve tested the FrSky telemetry on Navio2 and it worked just fine in the standard mode. The only limitation I should point out is the impossibility to use the passthrough feature.
As far as I see from the datasheet, the Taranis X9D Plus is compatible with FrSky X series, D series and V8-ll series receivers. Horus transmitters are declared to work with all ACCESS receivers.
Thanks a lot, for your support !
I have understand, i must connect “SBUS OUT” to PPM/SB NAVIO2 input for send all commands From the Transmitter, to the NAVIO Module.
For the telemetry, there is “SBUS IN” on the FrySky receiver, where i do connect “SBUS IN” for get telemetry information from NAVIO2 ?
