Emlid Flow 360 Browser Exports Failing
I’m experiencing an issue with exporting data from the Emlid Flow 360 browser application. All exports I’ve tried from the browser are failing.
When I initiate an export, I first receive the following message:
“Export started. This may take a while. You can close this dialog and continue using the app.”
The export then fails and I receive an “Export failed” notification with the options “Try again” and “Dismiss.” This occurs with all export formats, csv, shapefile, etc.
I am still able to export the same data directly from the Emlid Flow mobile app (version 15.4) on my phone. The issue appears to be specific to exporting through the Flow 360 browser application.
I’ve tried exporting across multiple computers, browsers, and Emlid accounts. All are failing.
Has anyone else experienced this issue with Flow 360 browser exports? Is there a known issue or recommended workaround?
Thanks!
Hi @J12 ,
Is it possible that your IT team blocks some of the storage hosts? If yes, please ask them to add https://s3.eu-central-003.backblazeb2.com to the firewall exclusions.
That was it, thank you!
