I’m using Emlid RS2 as a base station sending corrections to multiple rovers over NTRIP Emlid Caster.
Emlid casters clearly states that I can connect up to 10 rovers at the same time. However, only one rover works at same time. If I connect more than 1 rover, only one will be able to connect. The rest will never connect.
I’m using this same credentials for all rovers. Am I missing anything here? Did anyone have the same issue before?
I can see on the Emlid caster page I do have 4 rovers up.
What is limited to one is the NTRIP server stream on one mountpoint (“one base per mountpoint” thing). That is why you have 5 of them in the base section of the caster page.
Could you please share some screenshots of your configuration, base and rovers ?
That is exactly what I would expect.
I have one base (one mount point) and 2 rovers connecting at the same time through NTRIP EMLID Caster.
Below is an image of my caster.
