Emlid Caster dropouts
Hello,
today I had issues with emlid caster. I had several dropouts.
Is there any problem with your side or is it mine?
Hi @vgo195,
I checked in with the team. We are sorry if we caused any disturbances. We indeed did some changes, but it should work fine by now. Please let me know if you still encounter any issues; I will look into it.
Thanks for the reply,
thankfully I logged raw data and PPK’d the dataset.
The problem is that after the first dropout, I had to return to the base to set it again.
After the second dropout I was far away and had to switch to CORS.
You may consider fixing the base mode to reconnect by it self in case the caster goes down.
If this is possible of course.
Hi @vgo195,
Hopefully, there won’t be any more interruptions. Also, I agree about the automatic reconnection. I’ve passed this to the developers. I’ll let you know if there is any update about this.
