why sometimes emlids can break up on even though the signal is good???
Hi @fadhlyarafat84,
Can I ask you to clarify your issue? What device behavior do you face?
Also, please, share your Reach device model.
Please, answer questions from the previous message so that I can help you with the issue.
emlid as rover can turn itself off if it turns on again it will die again and so on, sometimes it dies sometimes it doesn’t die. ho to solve it???
Which version of ReachView is installed on that RS+?
ver. 2.16.2
How long do you leave it on the charger before using it? (also what type of charger do you use)
6 h. Using charger samsung
Please, leave the device on a charge until the orange LED will not be solid. Note, that it could take a long time.
Only after that try to boot it.
Let me know about the result.
A post was split to a new topic: RS+ charge time
I have tried but my device still dies itself when I do work
Can you double-check the link, please, as there’s 404 error?
ok VID-20190305-WA0037_1556364788004.zip (3.9 MB)
Please email us on support@emlid.com. In your email, indicate the serial number of this RS+ and order details.
Sorry for the inconvenience!
i send it email support@emlid.com
