Is it possible to use my Emlid RS3 base station to provide RTK to my farm equipment GPS systems? Currently I am operating Outback GPS, John Deere GPS, Claas S10, and Case IH Trimble systems. Mainly looking at the Outback systems over the other ones
Hi Riley,
Welcome to the forum!
Yes, you can use your RS3 as a base with your farm equipment via Emlid Caster. Reach broadcasts corrections in RTCM3, so as long as your receivers support this format, it should work.
Here’s the guide if you’d like to give it a try. Make sure both the base and rovers have Internet access. Also, are you planning to set up the RS3 as a permanent base?
