I found myself having issues on elevation difference between RS2+ and RS3 connected through NTRIP (as rover), approximate of 0.60 sft higher using RS3. I might be using wrong high pole, which is 1.8 m (5.906 sft) for both units.
Hi @luism,
Can you please share your data with this elevation difference? I’d take a closer look at it. If you’d like to keep it private, you can also send it to support@emlid.com.
If you’re using the same pole with the same height, it shouldn’t affect the collected coordinates. Did you set the same height in Emlid Flow?
