Is it possible to stream the video from edge on Mission planner instead of qgroundcontrol?
Hello.
There are no start/stop mavlink commands in MP. So you can’t control it using MP.
For now you can setup your stream with QGC, close it and after start MP. If everything is correct you should see video stream in a HUD. Also check port for stream - HUD right click -> video -> Set GStrreamer Source. The default port for QGC is 5600.
