I am configuring my edge fc and i seem to have a problem with the power module (connected to pw1 port)… it reads incorrect voltage… I use QgroundControl tuned for edge but there is no option to calibrate the power module… so i calibrated the power module in mission planner but when i switched back to QgroundControl the selected power module changes from edge pwr1 to other…
Thanks for the reply… i got the same settings after i calibrated the voltage in MP… my only concern was that why ‘other’ is selected instead of Edge PWR1 in power sensor tab ?
I’ve got similar issues with my Edge power module. Voltage readings fluctuate +/- 2V under no load and it infact increases when under load! Adjusting the multipliers doesn’t help - it moves the values into the correct magnitude of around 25V (6S) but as I said fluctuates wildly from that. Consequently the current sensing is also wildly off. QGC says I’m using 30% of my battery in the few minutes between power on and flight!
