E/Flow NTRIP client sending weird TLS-SSL messages on caster handshake
Whilst doing some work on my caster (SNIP Pro v3.20.1) I noticed in the console log that whenever an Emlid Flow client connection came in, it would log an error in the console;
“…Bad UnsupportedTLS-SSLreq”
Just to be clear this does not happen with any other NTRIP clients. I’ve even tested/isolated the error by loading another survey / mapping application with an inbuilt NTRIP client (Mapit GIS) on the same client device and it does not reproduce the same error. So it’s not iOS or VPN, cellular network, firewall or anything proxy etc related mangling the messages.
I’ve sent my caster console logs to the team at SNIP and like me they are very confused as we all thought the NTRIP client within Emlid Flow was just a ported version of RTKLIB - so basically NTRIP v1.0…
So my question to the Emlid team is what is this TLS-SSL malformed message stuff on handshake with the caster all about?!
I will see if I can post up more detailed messages from my caster debug log to help.
Caster log entry for Emlid Flow NTRIP client connection:
Caster log entry for MapitGIS NTRIP client connection (on same device):
(sensitive information is redacted above)
So why is the NTRIP client within Emlid Flow sending TLS / SSL headers - which are consequently being rejected by the caster (and the connection is then micro dropped by the caster)?
Hi @DirtyHarry, to clarify, are you using Reach as a base and sending its corrections through SNIP? If so, to investigate further, please share a Full System Report and the time at which the issue occurs. You can send it to [email protected] and mention this thread, since it may contain sensitive data. I will check it further.
Hi @merryna.anggriani - I’m using non-Emlid GNSS bases and the SNIP caster.
The error messages are generated when Emlid Flow is the NTRIP client (with an RX2 is being used as a rover).
If I use another NTRIP client (with same endpoint device/handset), then it’s all fine and connects without any of these TLS-SSL handshake oddities being logged at the caster.
I’ll send you the FSR logs from within Emlid Flow.
Got it, thanks for the clarification! Feel free to share with me the Full System Report and I will check it further.
That’s done now. Many thanks @merryna.anggriani
Thanks, I received the data and will check it further! Let’s continue the communication via email. Once we have a resolution about this, I will update this thread.
Hi Merrryna
Further to our various emails - I now understand that this is a design ‘feature’ of the NTRIP client that means its tries various connection protocols when first connecting.
As NTRIP casters are variously logging this connection attempt as an error condition (especially since on the face of it there’s nothing in Emlid Flow NTRIP client setup pages to suggest it will connect as an NTRIP 2.0 client i.e. with a TLS/SLL handshake) - then you may want to consider putting a note somewhere in the documentation about it.
Me an the guys at SNIP were chasing down various scenarios - as to the best of our knowledge Emlid Flow outwardly appears to be a NTRIP 1.0 client - we were really perplexed why we should be getting these errors…
Thank you for bringing this case and for the feedback. I am passing the feedback to the team!
