I’m building a 4G drone that streams all data through and online server.
I’ve set up a host on Amazon (AWS) with a static IP and succesfully configured my Navio2 to send to the mavproxy server to intercept, log, and forward the telemetry data to mission planner.
I’ve also set up video streaming and recording through the server using the RTMP protocal and ffmpeg from the PI and NGINX on the server where I can connect from anywhere with VLC to view the stream.
The problem? Latency…
Gstreamer works great over the local network and its lightweight on the PI2 but I havent found a way to run a DVR and remote viewer through the server. (with all the codecs, pipes, and configs I get lost easily)
RTMP is over TCP so it’s terrible for the 4G connection from the PI. On my hotspot I’m getting sometimes more than 10 secs of video lag!
Ideally both video and telemetry comes from the Navio/PI is over UDP to the server where it is recorded and “converted” into a TCP connection where I can connect from any computer.
Do you know a better way of doing this?
