djvferrari
(Vinicius Ferrari)
July 20, 2020, 1:40pm
1
Recently I had problems with the timemarks(timestamps) recorded by Reach M2 (L1+L2+L5). With Reach M+ (L1) I never had this type of problem.
In some points the timemarks are duplicated. I Checked the hotshoe on the camera and everthing is ok. Has this ever happened to anyone?
I attached the processed file and the image showing the duplicate points.!
Hi Vinicius,
May I ask you to use our latest RTKLib version for post-processing? You can download it here.
There should be no issue with the extra time-marks if you work with it. Please keep us updated.
djvferrari
(Vinicius Ferrari)
July 22, 2020, 1:09pm
4
Hi Polina! Thanks for answer, sorry for the silly mistake!
I Was using a version from two months ago. Using the last version (rtklib-qt-win-v2.4.3b33+8e953f3) is worked fine!
Vinicius,
It’s okay! Good to know you can get only necessary time-marks now
I’d also suggest keeping all your receivers on the latest stable firmware versions as they usually contain a lot of important fixes and improvements. Currently, it’s the v2.22.5 stable update.
system
(system)
Closed
October 30, 2020, 1:30pm
7
