Is it possible to duplicate a project in Emlid Flow?
Sometimes it would be nice to be able to create a clone of a project..
Massimo
Massimo
Not just a single-click copy but you can export CSV (all columns). Create a new project. If you have saved a localization you can select it as your project coordinate system by choosing Custom and it should be saved in the list. Once done import the CSV you exported back in.
Hi Massimo,
As @michaelL mentioned, currently there’s no quick way to duplicate projects. However, I noted your comment as a +1 in our internal request list.
Thanks.
Sometimes a clone option would be more effective than an export/import, even if the workaround will do nonetheless.
Massimo
