I’m new to this, I’ve mounted a reach M2 receiver on the Phantom 4 Pro, I’ve made a first flight and got all the events as float. The base cors was set up about 25km away. What have I done wrong?
25 km baseline for kinematic data is bit far away.
Did you get the 1 hz data, and not the 30s interval ones?
Feel free to provide the raw data for troubleshooting
I usually set a static receiver onsite when imaging a site. Even when I have either RTK with the receiver or using our states RTN. In case of cell coverage loss, I can still post process all the flights baselines and have confidence in my positions.
Long baselines will not converge to a “fixed” solution in your case.
Hi Luis,
Welcome to the forum!
Could you share all your files with me? It’ll help me investigate the issue further. You can use Google Drive or WeTransfer.
Also, I’d suggest sending them via PM or to support@emlid.com. Thank you!
