I’m on the ardupilot forums working on a few issues there. I submitted my logs and this was the reply:
This is development version and not ready for prime time. I would switch back to 3.3.3.
This version made some major changes to how the motors work and your PID’s don’t look right and maybe causing your issue.
Mike
I followed the instructions listed for Navio2 in the DOC section, what do I need to change to be able to use the stable/production version?
Thanks
You need to compile the code yourself:
http://docs.emlid.com/navio2/Navio-APM/building-from-sources/
just be sure to use the correct tag for the version, so it really is the version you want.
First do
git clone https://github.com/diydrones/ardupilot.git
cd ardupilot
git submodule update --init
and then switch to the correct version with Version tag
cd ArduPlane
git checkout tags/ArduPlane-3.5.2
The only copter related tag with 3.3.x is “Copter-3.3.2” though…
Thanks. Can I not used this one?
Is there a way to get notifications if the suggested install used on the Document page changes?
Yes. Then just use “ArduCopter-stable” as tag:
cd ardupilot
cd ArduCopter
git checkout tags/ArduCopter-stable
make navio2
This will result in an ArduCopter.elf which you can rename to Arducopter with
mv ArduCopter.elf ArduCopter
