Some of the GLONASS backup satellites (for example R26) are used in reach view 2.22.4 using the Reach module. One may doubt whether this is correct. Even if they send correct signals, which are not guaranteed by the system command, they are not in the almanac (ephemeris identify as R26), which delays the algorithm’s calculation process in real-time measurements.
This situation, apart from extending the computation process in real-time, can also result in erroneous results. Is it better not to do such experiments at all, i.e. exclude these satellites from the application? raw_202004241531.zip (1.4 MB)
Glonass R26 satellite is L3 band, I eliminate it at the moment of making the rinex. If you don’t want to see it in rechview you have to ask emlid to exclude it in the algorithm
