Hello,
It seems I am unable to use the emlidtool to start arducopter, and it’s because I’ve possibly fried the Navio.
I have a Navio2 device for a RPi3 and to connect them I use a longer extension cable, in the event of being unmindful I may have installed the Navio device wrong way around. Is this a mistake that would fry the device? There is a LED on the Navio which I would expect to light up, but it does not. I’m certain that this is not a software related problem, the Navio device is simply not detected by anything, hence the error in emlidtool “Seems like you booted without Navio properly screwed!”
The steps I’ve taken to reproduce this:
- Install the Emlid OS on the SD card
- Connect Navio2 unto the RPi3, insert the SD card and power cable
- Connect to WiFi by keyboard and monitor
- Disconnect keyboard and monitor
- SSH into the board from my laptop
- Upgrading the system
- Attempt to run
$ sudo emlidtool ardupilot
Rebooting even multiple times does not fix this error.
If the board is fried I assume there is not much I can do to save it, but any advice is appreciated.
