I know they work with 2.4GHz, but I also have 2 older RS units that are connecting to a 5GHz wifi, but 2 M2’s do not see the 5GHz wifi? Weird.
Hmm? Specs state 802.11 b/g/n
“n” 5GHz?
Hi @timd1971,
The hardware components inside those receivers are different. Reach M2 works only with 2.4 GHz Wi-Fi networks while RS can also connect to 5 GHz networks.
Well, there you go!!! I knew i wasn’t seeing things! Thank you!
