Dji Matrice 4E PPK impossible
We are used to PPK with emlid studio for GNSS and drone data (Dji Mavic 3E).
But now we need to do PPK for Matrice 4E images. But it appear it’s almost impossible to get fix. But it works well with Dji Terra.
It seem that some observations datas are not read by Emlid Studio. Especially the L2 band.
Does someone know how improve the situation?
Hi @topo1 ,
Let me check it for you. Can you send your logs to [email protected]?
I’ll check what we can do. What kind of environment did you set up the base in? Are there any high-power lines, radio transmissions, buildings, or trees nearby? These can interfere with the satellite signals. The SNR values indeed seem low.
What was your baseline distance from your base?
I’m also having a lot of difficult on getting good fixed flights on the DJI Mavic 4E. I’ve noticed that closing the mask angle to something like 30 degrees helps to improve the post-process, but also noticed some “false fix” by closing the mask angle too much, checked some flights with GCPs.
I’ve been using the DJI Mavic 3E for the past 2 years, it fixes the flights like a champ compared to Matrice 4E…
Does anyone have any idea on how to improve the PPK quality for the DJI Matrice 4E?
Hi guys!
So we were able to achieve FIX in the end. We excluded the satellites with those “spotty” signals by using the Convert to Rinex option. In the Kinematic processing setting, we’ve set the elevation mask to 17, and it has fixed it.
I was able to get a FIX solution on some flights by excluding satellites too, some not. See how bad is the observation data from Matrice 4E:
It is very poor compared to the Mavic 3:
Even I can achieve FIX solution for the whole flight, I’ve noticed errors bigger than 15cm on GCPs for the Z (height) with GSD of 4cm. Also tried RTK during flight, same thing happened.
We have a M4E and we absolutely do not have these issues with poor observation data. I’m suspecting you have a hardware issue.
Hi @thiagokern,
Thanks for sharing your results! You noticed the vertical differences after processing the photos, correct? It’ll be helpful if you could generate a processing report from your photogrammetry software.
Also, were your GCPs surveyed using Reach? If so, please share the full CSV export from Emlid Flow. You can send all the data to [email protected]. I’ll check where the Z offset may be coming from.
Could you share some observation print like mine to compare? I’m talking to DJI’s support team, this could hep a lot… Thanks!
Hello!
The points were collected using a CHC I73 RTK. Those points were double checked already. Also, the Z offset is not regular for the whole flight, it varies a lot to positive and negative errors…
Hi @thiagokern,
Sorry for the late reply. Which photogrammetry software are you using? Could you send a processing report from there?
Sorry for the delay, I’m trying to get my hands on an observation file. The stuff is on a server for which I don’t have access right now. I’ll send you a DM as soon as I get one.
