Hello,
The same is true with my post-processing.
The post-processing result is correct and reproduces the route taken on the street, with 88% of the Q = 1 data corrected.
However, the event file, the record of images collected by EMLID M2, does not reproduce the same path, they are dispersed in positions extremely distant between tens and hundreds of meters from the processed position next to the post-processed file.
I’m using the b33c version.
I also tested on the recommended versions b31 and there was no change in the final result presented.
