I would also try the servo example. Props off!!!
Possibly bad ESC or Motor? try swapping things around if you can and see if the problem persists in the same place or moves with the motor or ESC.
Yes i tried to change ESCs, servo example i didt tested, i will . I think that acc something is wrong, maybe calibration acc, because acc example works (i think it works ok). I used mission planner version 1.3.19, …
Thanks.
First thing that we should check is whether IMU works correctly, if HUD in the mission planner responds correctly than your accel and gyro are fine. From this point only configuration can go wrong and we need to find where exactly.
so, could you tell me the steps to check step by step?,please , i spent a lot of time reconfiguring and i don’t know what to do more…
yes, it is working
Now, i’m using navio raw on Rpi with Raspbian January img, would be better RPi2 model B?
