Yes! I’ve noticed that too. But why it’s different from another computer? I’ve just checked the navigation and observation files, they all have the same date (20230223, the date of the surveying).
And I sent the files to a coworker who also uses the Emlid Studio, the results were correct.
I agree with Florian – it looks like the start of the log was detected improperly, which caused the difference in the results. Most likely, you’ll get 100% Fix if you enter the correct Logs duration in the settings.
Still, it shouldn’t work this way, so I’d like to look closer into it. Can you share the log and details about your PCs (model, OS version) with me? You can send them via support@emlid.com.
Sorry I wasn’t clear enough – I meant the data you used for post-processing. I don’t remember any similar cases, so I believe we’ll need to check the particular dataset to understand what’s wrong. You can share the logs with me in PM too.
Also, if you tried to process other datasets on this PC, were they processed correctly?
