dicky
(dicky)
April 16, 2017, 10:54pm
#1
I post processed my rover with different positioning mode, and got different result. This is the picture
And this is the base and rover file
And one more the, which one is the true result??
This is the file https://drive.google.com/file/d/0B4NFPYGvPmMvZWRqd0hUc2pTdTA/view?usp=sharing
It’s strange… Is it a bug??
TB_RTK
April 17, 2017, 6:11am
#2
I got the same on both. Even the same result when changing kinematic and static
alujoe
April 17, 2017, 8:01am
#3
More alternatives using RTKPOST v2.4.3 Emlid b27
Positioning mode kinematic using rover.obs, base.obs and base.nav
Positioning mode kinematic using rover.obs, base.obs and rover.nav
Positioning mode static using rover.obs, base.obs and rover.nav
TB_RTK
April 17, 2017, 8:44am
#4
Oh, forgot. i run 2.4.3 b26
TB_RTK
April 17, 2017, 10:05am
#5
I think your config.is messed up or bad/wrong configuration. Delete it and try again
Used emlid b27 and got 4 of the same. Got possibly get better fix with some tweeking
Kirim to the left and Kirim1 to the right. Bottom pictures in kinematic and top pictures in static.
alujoe
April 17, 2017, 6:17pm
#6
Hi TB_RTK,
I use these settings, don’t know what is wrong ? Any suggestions ?
TB_RTK
April 17, 2017, 7:14pm
#7
Load this config and adjust to this image
R1.zip (14.2 KB)
dicky
(dicky)
April 18, 2017, 1:10am
#8
Thank you @TB_RTK and @alujoe , I will try rtklib from emlid. Where to download it?
TB_RTK
April 18, 2017, 4:38am
#9
dicky
(dicky)
April 18, 2017, 4:21pm
#10
Thank you @TB_RTK , I will try it.
