Can the option to position in real-time DGNSS mode be put back into ReachView?
As I understand it, the positioning in Reach is now either autonomous or kinematic where the AR solutions can either be fix or float.
Because I intend to use Reach in forest environments where cycle slips are to be expected, I was thinking positioning via differential code-phase measurements would be more reliable, albeit less accurate. Or is this a possibility in kinematic mode already?
In my case, I do not require centimeter accuracy, decimetre accuracy will suffice if they can work reliably under canopy.
