How do I fix this I’ve tried reflashing with zadig and it said it failed.
I’m really not sure what to do here.
Hi @ROSEISLE,
Would you mind elaborating on the issue? Do I understand correctly that the reflashing process of your device failed?
yes the reflashing failed
I’m using a surface pro and plugging an M2 into its USB port
Would you mind describing what urged you to perform the reflashing procedure? What issues did you face?
The “device descriptor failed” issue
Hi @ROSEISLE,
Thanks for your patience.
It seems like the Reach M+ is not recognizable by your Surface Pro computer. Usually, issues with the recognition are connected with the USB cables that you use.
May I ask you if you have tried using other USB cables and different USB ports on your laptop?
yeah thats what was wrong
