When Im collecting points with Emlid flow and RX, Can I set somehow description tab to be always active so i can only insert code of point surveyed. Now for every point i need to highlight description tab and activate basically. I need this to be active all the time so i can just insert code or number for code.
Hi @k_dm49,
Do I understand correctly that you would prefer that the app automatically select the Description field during a point measurement? So you wouldn’t have to manually tap on it?
Yes that is correct.
I see. Thank you! I’ll note it and pass it on to the team to consider further implementation.
