Hy Igor
I created a new config with my credential for ntrip. How can set up the reach device to have always this config when I connect the reach every time I need ?
thx
Francesco
Hy Igor
thx
Francesco
Once you save a new config, the app will offer to load it to the device. Load basically means use. After you saved it, Reach starts processing location data and remembers current settings, like Rover or Base mode, loaded config file, whether the processing was started or not.
If you power it down, after boot device will continue just where it left off with the same mode and config. The only exception is the log which will now be written to a new file with a new time
