Ok so i think figuring this out is on the list for winter projects. I want to see if i can pull off this trick for a 24hr period.
So RTK Extend apparently gives you RTK accuracy for two weeks with no corrections after only a 20min RTK session. I know it sounds like some heavy voodoo.
So the first step to solving this is i have to figure out how to store and replay old corrections, I know this is not the solution but i think its part of it.
Next i think i need to see if there are any generalized patterns in the corrections that can be used to calculate and modify the stored corrections as the originals degrade over time. This is under the assumption that the ionospheric changes happen like waves and head in a generalized direction.
Also I have a trimble that can pull off a moving base, I will see if the deere system has to do with comparative error from a second tractor mounted “moving base” receiver.
Then mow my lawn in the spring and see how bad my math is.
So does anyone else have any guesses or theories how you can pull off a two week disconnect and maintain RTK accuracy?
