Hello
Is it possible to run a service on Reach RS2 that update an DDNS with reach public IP?
Thanks
André
Hello
Thanks
André
Not an answer to your direct question, but another solution:
Hello, thanks for the answer, but Reach RS2 have the resources to do it and using a router in the field is na extra non need thing.
In this case the Reach RS2 is running with a SIM card with a public IP.
This is possible with a service running on boot, but I don’t know how to do it without root login.
Thanks again
André
Hi André,
There’s no root access on Reach RS2 so I’d go with the solution offered by Christian.
Hi again,
It’s disappointing, anyway, is it possible to run a script on boot with the normal user (reach)?
Hi André,
We don’t recommend running scripts on Reach as adding any custom scripts or drivers may cause issues that we won’t be able to troubleshoot. I commented on this in another thread in more detail:
Thanks Tatiana,
I’ve read that for my disappointment, and in part I understand.
So, the purpose of SSH access is mostly for download?
In the meantime, SSH indeed is used as a backup way of getting logs
Ok Thanks again for all information shared.
