I want to extract the date of logg files. I have survey the point on October 21, 2020. But when I go the logg file. It show the logg file October 22 and October 23. I havent survey any point on those date. I believe there is something wrong with dates
You could look at the rinex file if you have one, it’s in the header and throughout the file.
Hi Hasti,
Reach receivers use the UTC time, that is why you may experience the offset in dates in correspondence to your local time. Could you please PM me the raw data, solution and base correction logs so that I could check if it is indeed the case?
