Hi im new user!
Hi everyone!
I’m a rs2 owner
I’m trying to log in to an NTRIP caster and send data, but I can’t see what’s happening in reach view. There is no signal in the caster. And I think the username-password pair for login is missing.
Others tried it?
Gabor
Hi Gábor,
May I ask you to clarify whether you want to output RTCM3 from Reach RS2 base to an NTRIP caster or get corrections from NTRIP caster on Reach RS2 rover?
What’s the caster you use?
Dear Tatiana,
I would like to use RS2 as a base, I would like to send a correction to CASTER so that I can work with different brands of rovers in a workspace.
The CASTER: lefebure
188.142.210.33:8888 this port is port 80 for the caster
188.142.210.33:2101 This is the NTRIP port for the caster
user / pass = emlidbase / emlidbase
I have 3 leica GRX 1200+ base station, in every day use with the LEFEBURE CASTER
I started to sending correction here. But I don’t understand what EMLID is doing.
Does not log in to CASTER. There is nothing in the CASTER log
I missed something?
Meanwhile, the NTRIP correction was being received.
Thanks!
Regards
Gabor
Hi Gabor,
How do you provide Reach RS2 with the Internet? Do you use Mobile data from SIM card or get it connected to a Wi-Fi network?
Also, may I ask you to describe all the actions you accomplish during this setup with screenshots showing each step?
