Is it possible to have the RS2+ log data on the hour? I have it set up to log 1 hour data files but it starts and stops the 1 hour from the time logging is started.
Hi Anthony,
Do I understand correctly that you would like to split the log exactly when the hour starts? For example, at 14:00, 15:00, etc., regardless of when you started logging. Can you tell me more about your workflow and why it will be useful for you?
I have the RS2+ setup as a permanent base continuously collecting data. I have the “Split logs interval” set to 1 hour. It would be ideal if it stored them on the hour like the other gnss brands do.
Anthony,
I see. And if you started not on the hour (9:03, for example), do you want Reach not to log until the hour starts?
If it starts at 09:03 then it will log to the file until 10:00 and start a new file at 10:00 and log till 11:00
Anthony,
Thank you for explaining to me! I’ve passed your request to our development team. Once there are any updates, I’ll be sure to let you know.
